Querying a table does not return all fields
2350
5
10-16-2018 06:41 AM
KyleSchultz1
               ServiceFeatureTable {
                           url: ""
                           credential: Credential {
                               username: ''
                               password: ''
                           onQueryFeaturesResultsChanged: {
                               if (queryFeaturesStatus === Enums.TaskStatusCompleted) {
                                   if (!queryFeaturesResult.iterator.hasNext) {
                                       return;
                                   workLog.clearSelection();
                                   var features = []
                                   while (queryFeaturesResult.iterator.hasNext) {
                                       features.push(queryFeaturesResult.iterator.next());
                                   workLog.selectFeatures(features);
                                   var identifiedObjects =[]
                                   var elem = features[0];
                                   identifiedObjects.push(elem);
                                   displayAttributesModel.append(elem);
                                   for (z = 0; z < displayAttributesModel.rowCount(); z++) {
                                       console.log(JSON.stringify(displayAttributesModel.get(z).attributes.attributeNames))
I have this code that is being invoked
        params.whereClause = "GlobalID = '" + activeID+"'" ;
        workLogTable.queryFeatures(params);
I have all these fields
  • OBJECTID ( type: esriFieldTypeOID , alias: OBJECTID , editable: false , nullable: false )
  • CREW_RESPONDING ( type: esriFieldTypeString , alias: CREW , editable: true , nullable: true , length: 1073741822 )
  • WORK_SUMMARY ( type: esriFieldTypeString , alias: WORK_SUMMARY , editable: true , nullable: true , length: 1073741822 )
  • WORK_DETAILS ( type: esriFieldTypeString , alias: WORK_DETAILS , editable: true , nullable: true , length: 1073741822 )
  • HOURS ( type: esriFieldTypeDouble , alias: HOURS , editable: true , nullable: true )
  • MATERIALS_USED ( type: esriFieldTypeString , alias: MATERIALS_USED , editable: true , nullable: true , length: 1073741822 )
  • EQUIPMENT_USED ( type: esriFieldTypeString , alias: EQUIPMENT_USED , editable: true , nullable: true , length: 1073741822 )
  • BOIL_ADVISORY ( type: esriFieldTypeString , alias: BOIL_ADVISORY , editable: true , nullable: true , length: 75 )
  • ACCIDENT ( type: esriFieldTypeString , alias: ACCIDENT , editable: true , nullable: true , length: 75 )
  • LAW ( type: esriFieldTypeString , alias: LAW , editable: true , nullable: true , length: 75 )
  • WORK_TITLE ( type: esriFieldTypeString , alias: WORK_TITLE , editable: true , nullable: true , length: 75 )
  • CREW_ADDITIONAL ( type: esriFieldTypeString , alias: ADDITIONAL , editable: true , nullable: true , length: 1073741822 )
  • CREATED_BY ( type: esriFieldTypeString , alias: DATA_ENTRY , editable: true , nullable: true , length: 75 )
  • GlobalID ( type: esriFieldTypeGlobalID , alias: GlobalID , editable: false , nullable: false , length: 38 )
  • created_user ( type: esriFieldTypeString , alias: created_user , editable: false , nullable: true , length: 255 )
  • created_date ( type: esriFieldTypeDate , alias: created_date , editable: false , nullable: true , length: 36 )
  • last_edited_user ( type: esriFieldTypeString , alias: last_edited_user , editable: false , nullable: true , length: 255 )
  • last_edited_date ( type: esriFieldTypeDate , alias: last_edited_date , editable: false , nullable: true , length: 36 )
  • STATUS ( type: esriFieldTypeString , alias: STATUS , editable: true , nullable: true , length: 75 )
  • DEPARTMENT ( type: esriFieldTypeString , alias: DEPARTMENT , editable: true , nullable: true , length: 75 )
  • UPDATED_BY ( type: esriFieldTypeString , alias: UPDATED_BY , editable: true , nullable: true , length: 75 )
  • CLOSED_BY ( type: esriFieldTypeString , alias: CLOSED_BY , editable: true , nullable: true , length: 75 )
So the line
is only outputting
qml: {"0":"created_date","1":"created_user","2":"CREW_RESPONDING","3":"GlobalID","4":"last_edited_date","5":"last_edited_user","6":"OBJECTID"}
meaning the majority of my fields aren't being returned. So attribute values I need to display are not being displayed in my app.
Is this a known issue? Is there a way to solve it and return all fields?
KeithLarson1
Sure. All you need to do is replace this:
with this:
         workLogTable.queryFeaturesWithFieldOptions(params, Enums.QueryFeatureFieldsLoadAll);
KeithLarson1
If I'm understanding this correctly, this is the same problem I was having before. I was able to specify the fields to return with the queryFeaturesWithFieldOptions function rather than queryFeatures. I passed it Enums.QueryFeatureFieldsLoadAll to return all fields. It is documented here: ServiceFeatureTable QML Type | ArcGIS for Developers . Hope that helps.
KyleSchultz1
Could you post an example of how you used it?
KeithLarson1
with this:
KyleSchultz1
Thank you, such a simple soultion
ErwinSoekianto
Esri Alum
I think this is similar to this thread, How to use QueryParameters and specify outFields?
It is because there is no outfields parameter being set, someone has reported success using "queryFeaturesWithFieldOptions" method which will return all fields.
cc: ArcGIS Runtime SDK for Qt
