Python script in export pdf with fieldname
2082
5
10-12-2018 08:43 PM
ChanYuk_Yu
Hi, I have the script below. I am trying to export 400 pdfs with the fieldname "Label" but it only export the last page of pdf. What goes wrong ?
import arcpy
mxd = arcpy.mapping.MapDocument("CURRENT")
pageNameField = "Label"
for pageNum in range(1, mxd.dataDrivenPages.pageCount + 1):
        mxd.dataDrivenPages.currentPageID = pageNum
pageName = mxd.dataDrivenPages.pageRow.getValue(pageNameField)
pageName = pageName.replace("/", "_")
pageName = pageName.replace(" ", "")
print "Exporting page {0} of {1}".format(str(mxd.dataDrivenPages.currentPageID), str(mxd.dataDrivenPages.pageCount))
mxd.dataDrivenPages.refresh()
arcpy.mapping.ExportToPDF(mxd, r"C:\TEST\181013_test" + str(pageName) + ".pdf")
del mxd
DanPatterson_Retired
/blogs/dan_patterson/2016/08/14/script-formatting
There seem to be a few issues with code formatting that might be real or due to copying.
Throw in a couple of print statements to see what the page and output filename are printing as you go along.
You don't have to go through all 400, just check
print("page count {}".format(mxd.dataDrivenPages.pageCount))
And change this line to....
for pageNum in range(1, mxd.dataDrivenPages.pageCount + 1):‍  # ---- original
for pageNum in range(1, 5):  # ---- or some small number for testing
ChanYuk_Yu
Hi Dan
I am new in python, so I am copying and combined the sample or code posted to try to get a workaround.
Thank you for your suggestion. I tried range (1,5), the small test shows it only process the last page. I wonder if the problem comes from pageName because the code works all right when the second last script ExportToPdf is pageNum.
that could be it, but I you didn't post print statement to confirm
ChanYuk_Yu
I inserted the print code you recommended and another error comes up..  What goes wrong at Line 11 ?
Parsing error SyntaxError: EOL while scanning string literal (line 11)
Here's the code
import arcpy
arcpy.mapping.ExportToPDF(mxd, r"D:\TEMP\" + str(pageName) + ".pdf")
del mxd
You shouldn't use backslashes to end a path.
Also, check the link I sent on Code Formatting, especially if you want to refer to line numbers
a = r"D:\TEMP\"
  File "<ipython-input-1-c1bcefbc921d>", line 1
    a = r"D:\TEMP\"
a = r"D:\TEMP" + "\\somefile" +".pdf"  # ---- or
"{}\\{}{}".format(r"D:\temp", "somefile", ".pdf")
'D:\\temp\\somefile.pdf'
