Setting Scale Range
773
10-12-2018 10:41 AM
MichelleCouden
I am trying to set a layer to a scale range. For example, "Don't show layer when out beyond".  You could set this in ArcMAP and then when you zoomed to each point it would keep the scale of the map at your scale range. Where is that feature in ArcGIS Pro. I have the scale range on the layer at the number I want and I have the map properties at the decimal degrees. In Pro it is keeping a scale range way closer in range than what I am asking it to do. Am I missing something in Pro??
