join layers with code c#
969
10-04-2018 10:39 PM
ThomasMENARD1
hi,
i'm developing an addin with ArcGIS pro SDK.
This is what i expect my tool do (in Arcgis Pro project):
1-clic on addin button or control
2- check if layers are in project
3- make join between both layers (Primary key, foreign key is static or known parameters in code)
4- display labels building with expression of joined attributes
Step 1,2 and 4 are successfull.
For step 3, i follow instructions at : ProConcepts Geodatabase · Esri/arcgis-pro-sdk Wiki · GitHub
But no joins is etablished. Maybe, it's not on client-side?
Wolf
by Esri Regular Contributor
There is a sample that shows how to dynamically join feature classes or tables:
https://github.com/Esri/arcgis-pro-sdk-community-samples/tree/master/Geodatabase/DynamicJoins
