how to make a second (smaller) form on basis of hosted feature layer
1128
10-04-2018 01:40 PM
Wimvan_der_Drift
We use a webform to gather data from our citizens for the purpose of signal handling.
We made this in survey123 and published it on the web.
For internal use, we want to use a smaller form ( less fields) but the data should be included in the same table
What is the best aproach ? to make a second form . How does that work ?
thanks
IsmaelChivite
Esri Notable Contributor
Hi. If you want to publish a survey on top of an existing feature layer, you need to use Survey123 Connect. Have a look at https://community.esri.com/groups/survey123/blog/2017/09/25/working-with-existing-feature-services-i...  for the details. For the quick answer see the screenshot below:
IsmaelChivite
Wimvan_der_Drift
Tnxx Ismael, I followed your suggestion and in the end it succeeded. It took me a few hours (trial and error).
I think it only works properly from Survey123 connect, version 3.0.142.
We use cascade select in our initial hosted feature. The new form on the basis of this existing feaure layer starts with a simple survey123 excel, but by coping the two excel tabs (survey and  choices) from the original survey to the second form, and then adjusting it , worked fine in the end. So tnxx again
