Blind SQL injection for Geoprocessing service using arcpy.da.SearchCursor
732
10-03-2018 06:02 AM
MaximeDemers
I would like to know if a geoprocessing service that is using arcpy.da.SearchCursor can be subject to blind SQL injection if the where_clause parameter of the SearchCursor is one of the service parameter.
Is there a possibility that injecting SQL in the where_clause parameter can affect the integrity of the source table especially by using the SLEEP() command?
Thank you
Tags (1)
JoshuaBixby
MVP Esteemed Contributor
MaximeDemers
Thank you for the link, that helps a lot.
I read:
Standardized queries are applied to the entire ArcGIS Server site; they cannot be enabled for some services and disabled for others.
So if it's turned on on the server, standardized queries are being used for the where_clause in a arcpy.da.SearchCursor in a Geoprocessing Service right?
That do not just applied to standardized queries of MapServices right?
