Python script error message
5256
17
10-02-2018 12:03 PM
JimFritz
Any help with the error message below would be appreciated.
arcpy.env.workspace = outbufferpath
featureClassList = arcpy.ListFeatureClasses()
for featureClass in featureClassList:
    for row in arcpy.da.SearchCursor(featureClass,'SHAPE@'):
        arcpy.management.Clip(raster, row[0].extent, outrasterpath + featureClass, featureClass, -3.402823e+38, "ClippingGeometry", "MAINTAIN_EXTENT")
  File "<string>", line 3, in <module>
  File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 15215, in Clip
    raise e
  File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\management.py", line 15212, in Clip
    retval = convertArcObjectToPythonObject(gp.Clip_management(*gp_fixargs((in_raster, rectangle, out_raster, in_template_dataset, nodata_value, clipping_geometry, maintain_clipping_extent), True)))
  File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 496, in <lambda>
    return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000445: Extension is invalid for the output raster format.
Failed to execute (Clip).
JimFritz
Just some additional info.  There really is no extension for an ESRI format grid so this error message is hard to understand.
JoeBorgione
I see two 'clips':
Clip—Help | ArcGIS Desktop  where the syntax is arcpy.Clip_analysis(.....)
and
Clip—Help | ArcGIS Desktop  where the syntax is arcpy.Clip_management(.....)
Where is arcpy.Managemnet.Clip()  ?
DanPatterson_Retired
see below... it should be the clip in analysis
DarrenWiens2
What is this value?
You should be using Clip in the Analysis toolbox
Clip—Help | ArcGIS Desktop  same in arcmap or pro
Clip in management is for grids
DarrenWiens2
It seems they're trying to perform raster clip, so this (i.e. management clip) is the correct tool.
JimFritz
Yes, clip management is the right one, outrasterpath is defined below:
# out path to clipped rasters
outrasterpath = r"S:/General-Offices-GO-Trans/SLR-Mapping/GIS_Projects_2018/Smart_T_Line_Model/geodata/TEST_RASTERCLIP.gdb/"
Script is still not working.
from your script all I see is featureclasses,  Where is the raster coming from?
Something is missing.  Is the raster defined somewhere else?
can you provide what is needed for your raster clip, like... raster, outrasterpath.
also, you aren't specifying any file name for the raster so you will end up with esri grids which I am not sure if your nodata value minimum  (-3.402823e+38) is supported... maybe check that as well
JimFritz
Yes, hoping for ESRI grids as output.  Not sure where to check on the nodata value minimum?
