I am trying to figure out how to migrate data from points in collector to auto populate in Survey123. I created a form in Survey123, then embedded a link to the form in the popup for a layer which is viewed in Collector, so when you click on a location point the link shows up along with other attributes/data. I want some of the attribute fields that are also present for the location to auto populate in the Survey123 form.
For example; every location point has an address field, so when you click on the link within a point I want the address attributed to that location point to auto populate inthe address filed in the Survey123 location.
I have built out the Survey123 form in Survey123 Connect for ArcGIS Version 3.0.142
Take a look at the following: https://community.esri.com/groups/survey123/blog/2016/07/30/understanding-survey123s-custom-url-sche...
