Multipatch layer cannot be published to the current portal.
1489
09-27-2018 04:05 AM
AyokunleAdebisi
I try to publish a 3D web-scene and it gives me the error above and also feature will be flattened.So i search for solution, i realised that the arcgis datastore could not connect. I will like to know what step to take to solve this problem of datastore or any other solutions.
Tags (1)
LilibethJimenes_Medina
Hi adebisi Ayokunle, you could fix your problem of sharing the multipatch in the Portal For Arcgis? I am going through the same problem.
AyokunleAdebisi
Are you asking a question or you telling me how to solve it?
and is your problem solved now.
