Survey123 'Sent Inbox BUG'
1890
09-25-2018 07:35 AM
JordanMiller4
We're experiencing a bug editing an existing sent survey form for a job in Survey123.
 Survey123 Notes: 9/25/18
Secretary sent survey to operator
Operator received survey
Secretary went back into Sent box, made a revision, and sent again.
Operator refreshed inbox and the sent mail before the changes disappeared and the new revised survey didn't appear either.
Problem: Reopening and editing a sent survey form for a job disappears in the operator’s inbox.
Secretary Specs:
Operating System: Windows 7
Survey123 for ArcGIS - Desktop Application
Survey Version 3.0.149
AppFramework version: 3.1.113
Operator Specs:
Operating System: IOS 12.0
Survey123 Version 3.0.149
We're using this survey in an enterprise environment.
Enterprise system is version 10.6
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Jordan,
Thanks for the description.  Just to confirm, the secretary sent the revised form, then updated the Inbox (I'm not sure what you mean by refresh the sent box(?) - there isn't a refresh option). Is there a definition query applied to the Inbox that would prevent certain surveys from being seen?
JordanMiller4
Hi James,
Our secretary created an Odor complaint form this morning for an operator before he left the office. When the operator arrived at the job site he called back into the office to let the secretary know that the address number was incorrect. The secretary went back into her Sent box and edited and resent the survey. She asked the operator to go back into his Survey123 app on his phone and refresh the inbox. When he did that particular form disappeared. For whatever reason going back into the Sent box and editing existing forms disappear completely in the inbox.
Our inbox filter(last image listed below) has no relation to the address box so I assume it has to be a bug.
DISPATCHEDTO =${username} AND FIRSTRESPONDERONSITE IS NULL
Thanks, Jordan
JamesTedrick
Hi Jordan,
Can you see the data in ArcGIS Online?  I am wondering if the FIRSTRESPONDEONSITE field was updated.  The act of editing should not remove a survey from what should be shown in the Inbox; changing the survey so that the condition that is applied is no longer valid would remove it from the Inbox on refresh.
JordanMiller4
Hi James,
Our survey is setup in an enterprise system. When I looked at the record on the back-end of the system the FIRSTRESPONDEONSITE field still looked the same. I will try to do some more testing after work later today. By chance do you know if anyone else has experienced something similar?
