Nested if statements
1766
09-25-2018 06:19 AM
AJM
I am trying to assign a label based on a size range but it is not working. Here is the stament I am using.
if(${c_lenght_cal} <= 5, "Hatchling", (if${c_lenght_cal} >5 and ${c_lenght_cal} <=10, "Post-hatchling",(if${c_lenght_cal} >10 and ${c_lenght_cal} <=60, "Juvenile", (if${c_lenght_cal} >60 and ${c_lenght_cal} <=92, "Subadult", "Adult"))))
What am I missing?
StephenM
It looks like you have the parentheses within the statement on the wrong side of the ifs.
This worked for me:
if(${c_length_cal} <= 5, "Hatchling", if(${c_length_cal} > 5 and ${c_length_cal} <= 10, "Post-hatchling", if(${c_length_cal} > 10 and ${c_length_cal} <=60, "Juvenile", if(${c_length_cal} > 60 and ${c_length_cal} <= 92, "Subadult","Adult"))))
For what it's worth, I think you might be able to shorten this statement as well. I don't think you need the > statements, since the previous <= statement will have already evaluated to true.
if(${c_length_cal} <= 5, "Hatchling", if(${c_length_cal} <= 10, "Post-hatchling", if(${c_length_cal} <=60, "Juvenile", if(${c_length_cal} <= 92, "Subadult","Adult"))))
StephenM
This worked for me:
AJM
Stephen
Thanks I just figure out the parentheses and got it working a little while ago also.
I like the idea of shortening the statement so I will give that a try !
JoshuaBixby
MVP Esteemed Contributor
If Stephen's suggestions work for you, please mark his comment as the answer to close out this question.
