Add layers in WAB app without using Widgets
914
09-20-2018 09:45 PM
PrashantKirpan
Hi All,
I am new to WAB(developer) and trying to add feature layers in application. I have found couple of customised widgets to add layers on map but is there any way to add layers without using any widgets?
I am trying to minimise widgets in my application so thinking to get urls from any(application config\setting) file and add layers to map?
Is this correct approach or should I use widgets only?
Any help would be appreciated.
Regards,
Prashant
AnthonyGiles
Honored Contributor
Prashant,
If these are layers that you want to be available to all users when they open the application then you should add the layers in to the web map that drives the application:
Map and Scene—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
Regards
Anthony
AnthonyGiles
Honored Contributor
Prashant,
Regards
Anthony
PrashantKirpan
Really appreciate your help Anthony,
I followed the steps mentioned in above link and it's resolved my issue.
Regards,
Prashant
