Trying to rotate icon differently for each unique value in UniqueValueRenderer
2073
09-18-2018 07:41 AM
ZacharyKlaas
Hi, why does this code rotate every item's icon instead of each icon separately?  I cannot get the necessary information from documentation available.  I want each unique value to have a differently rotated symbol:
l = m.listLayers("xylayer")[0]
sym = l.symbology
symList = sym.renderer.symbol.listSymbolsFromGallery("ShipAIS")
current = None
for symbol in symList:
  current = symbol
sym.updateRenderer("UniqueValueRenderer")
sym.renderer.fields = ["Combined_True_Heading"]
for grp in sym.renderer.groups:
  for itm in grp.items:
    itm.symbol = current
    if(itm.values[0][0] != "<Null>"):
      itm.symbol.angle = 360 - float(itm.values[0][0])
    else:
      continue
l.symbology = sym
DanPatterson_Retired
if itm.values[0][0] is not None:
<null> is how it shows in the geodatabase table, None is python.  Assuming it is not an empty string then you have to check a bit more
if itm.values[0][0] not in ("", None):
ZacharyKlaas
Thanks, Dan.
I made the change and it ended up not catching the cases that are null, probably because the data table this is being run on is the result of a join and what is in those cells are Strings (that is, the String "<Null>").
So presently I've changed this to "if itm.values[0][0] not in ("<Null>", None):" and it is still catching the instances where it says "<Null>", while also catching any other potential instances of no value for a particular cell, so it's an improvement in the code to be sure.
It's still not solving the issue with the icons rotating as a group rather than allowing me to rotate each individually, though.  Is there another way I can get at that?
