arcgis runtime app crashes after loading local Elevation
1244
09-13-2018 07:27 PM
PeterChen1
Hi experts,
I am using arcgis runtime .net 100.2.1. My WPF application with arcgis runtime crashes frequrently after loading my local elevation file. the crash happens when zooming in/out, or rotating the scene, is this a known issue and any ideas to avoid the crash?
below is my main steps to create the scene:
1,load the local slpk
Uri treespk = new System.Uri(slpkPath);
var sceneLayer = new ArcGISSceneLayer();
// add the scene layer to the scene
sceneLayer.Source = treespk;
sceneView.Scene.OperationalLayers.Add(sceneLayer);
2,load the local elevation file with "tif" suffix.
var elevationSource = new RasterElevationSource(myFiles);
// Add elevationSource to BaseSurface's ElevationSources
sceneView.Scene.BaseSurface.ElevationSources.Add(elevationSource);
JenniferNery
Can you check if updating to v100.3 will still cause a crash? If it's still reproducible with latest, do you mind sharing repro code/data? Thank you.
PeterChen1
Thanks for your quick reply.
Today I upgrade to v100.3 and yes the crash is gone.However, my scene layer is invisible when it's there when I was using v100.2.1,could you give me some idea on how to fix? Below is my code snippet to load my local slpk as an ArcGISSceneLayer:
sceneLayer.Loaded += SceneLayer_Loaded;
//await sceneLayer.LoadAsync();
By the way, the SceneLayer_Loaded is invoked so I am sure the sceneLayer is loaded without any error, just not visible.
I try to load the same local slpk via arcgis earth v1.6.1, it's visible on the earth.
