Print Template not returning field value
1264
09-13-2018 09:38 PM
JamesWilson2
I have a print template that will not return the value of one field. All other fields work. I have two nearly identical surveys where the templates work. I have tried my report template in those surveys and it works, I have tried those report templates in this survey and they do not work. I would say it is something wrong with the field, however the field works perfectly in AGOL, ArcMap and Pro.
Survey data is here
http://survey123.arcgis.com/surveys/ff5dd475f0a8497192e1e54736dd4a55/data
Estate data is populated
Estate information doesn't flow through to the example
Estate information doesn't flow through to the report template
any idea why this would happen?
JohnathanHasthorpe
Hi James
Can you share your survey .xls and print template?
John
JamesWilson2
GDay Mate, have added attachments to the original post
JohnathanHasthorpe
Hi James
I tested your template and all looks good. Can you have a go at creating a new survey using the files you shared with me? Please let me know if the problem persists.
John
JamesWilson2
GDay Mate,
I created a new survey using the same files and the error has not persisted, so it looks like it was a glitch. Fingers crossed it doesn't happen again.
