ArcGIS Pro/ArcMap .csv imports 8000-character String fields
6277
10
09-13-2018 08:49 AM
JasonMenard1
Has anyone ever had issues importing a .csv as events into ArcMap (or Pro) and having it interpret String fields with a length of 8000?  This winds up creating viable feature classes with the same issue that break most geoprocessing tools because of the field lengths.  I'd love to know how to avoid this.
2 Solutions
TimOrmsby
Hi Jason, this bug has been in the system a while. It's marked as medium severity. If it's breaking gp tools please contact tech support and reference bug number BUG-000086039 so the severity can be upgraded.
KoryKramer
Esri Community Moderator
I haven't tried this, but you could create a schema.ini file that defines the exact widths you want to define for each field in the csv that you're importing, and make sure that schema.ini is in the same folder as the .csv.
Here's some doc: Adding an ASCII or text file table—Help | ArcGIS Desktop
Here's a quick example I had sitting around in a folder:
Hope this helps!
DanPatterson_Retired
sample of a few rows?
sounds like you may be missing newline delimiters
AdrianWelsh
MVP Honored Contributor
Jason,
I've had this happen a few times but have not found any issues with geoprocessing tools. Which tools are not working for you?
TimOrmsby
That bug has been around for a while.  I haven't experienced it with csv files using ArcGIS Pro.  I have created them using text editors and as the outputs from numpy and other programs.
How was your csv file created? From Excel or some other program?
AdrianWelsh
Dan, I get the 8000 characters thing from CSVs and my CSVs are created from Excel. So, maybe Excel is the culprit here...
excel seems to be the culprit. But I use excel or quattro pro to produce csvs all the time but they go to numpy structured arrays and I usually set the dtype myself.  I will be paying attention more to np.genfromtxt to see the dtypes produced.
There is a related issue with file gdb's with TableToNumPy array.  So whatever is going on needs to be monitored if working in that environment.  PS, a schema is like setting a dtype for a structured/recarray
KoryKramer
Hope this helps!
AdrianWelsh
Kory, that sounds like an awesome work around. If it worked well, it would be good to add that to the bug information.
KarinBodtker
It works! I tried it today. Just make sure the schema.ini file is in the same folder as the csv or txt file you are importing/adding.
