Feature Class not Visible
4266
5
09-13-2018 10:04 AM
TatianaGarcia
I have a shapefile that I have added into my project on ArcGIS Pro but I am not able to see it. I can see the attribute table and when I click on zoom to layer it takes me to the correct location but I still can't see it. It has the same projected coordinate system as the rest of the layers I am using. If I select a feature on the map I can see the selected feature as shown on the attached picture.
I have tried to exported out as another shapefile but It has not worked.
Is there anything I can do to make the layer visible?
Thank you,
AdrianWelsh
MVP Honored Contributor
Tatiana,
Can you post a bigger screenshot of your ArcGIS Pro project? Is that aerial image layer on top of your feature layer? Maybe also try a Repair Geometry on your layer as well to see if that gets it behaving better.
TatianaGarcia
Adrian the aerial imagery is my basemap and I have the feature class layer on top not displaying.
AdrianWelsh
Tatiana, I'd be curious to see a bigger screenshot out of curiosity on how the layers are arranged. Plus, it doesn't hurt to try and using the Repair Geometry tool on your layer to see if it helps.
MichaelVolz
Esteemed Contributor
Can you try exportng the shapefile from ArcCatalog into a file gdb and then add the file gdb feature class into Pro?
DanPatterson_Retired
Open a new map devoid of any basemaps or any other file.
Add that one file to the map... can it be see now?
