Has anyone encounter this issue described below:
I have seen this happen frequently within the last few days and it seems to start to pick up its momentum, occurring more often than ever. When I am in ArcMap, I made an attempt to connect to a specific enterprise geodatabase. It would take a lengthy time to connect to the database. You would see an hourglass load forever and ArcMap will appear as if it is not responding. But that is not the case, because the connection will eventually connect. In terms of when it will connect, it is very inconsistent. It can sometimes take 5 minutes, 10 minutes, 1 hour, 2 hours and can even be more than that.
This is the only database that has this particular problem. When the issue occurs, I can still connect to other databases without any issue. I will admit that it is also the database that is being utilized the most. I would say there are at least 5-10 users connecting to the database and from different locations coming from US and Canada.
This issue will come and go and seem to resolve on its on. After speaking to our dba, they seem to hint there is some sort of blocking mechanism taking place from the SQL Server end. This is why it is preventing users from connecting to the database. We are still unable to determine the root cause of this. When we connect through SSMS, we do not have this issue. This issue only occurs when users are connecting from ArcMap.
Just hoping to see if someone has seen this issue before as we continue to investigate where the root cause is.
