Set datasource with ArcObjects
1432
09-12-2018 11:19 AM
LisaT
Does anyone know how to change a datasource with code with ArcObjects?  In 10.0 I used:
IDataSourceHelperLayer dsh = new DataSourceHelper() as IDataSourceHelperLayer;
dsh.FindAndReplaceWorkspaceNamePath(layer, pDatasetName.WorkspaceName.PathName.ToString(), newName, false);
This appears to be doing something in 10.6.1, but it is not changing the source as it should.  To explain, if I run the code and then open ArcMap, all of my layers still have "!" next to them.  However, if I check the datasource with:
IFeatureLayer layer = enumLayer.Next() as IFeatureLayer;
while (layer != null)
{ IDataLayer2 pDataLayer = layer as IDataLayer2;
if (pDataLayer.DataSourceName is IDatasetName)
{              IDatasetName pDatasetName = pDataLayer.DataSourceName as IDatasetName;
             string oldName = pDatasetName.WorkspaceName.PathName.ToString().ToLower(); }
    layer = enumLayer.Next() as IFeatureLayer; }
The oldName shows that the path HAS been changed.  Why isn't it displaying in the map?  Am I missing a step (I save the map)?   What is the best way to programmatically change datasources in 10.6.1?  I need to create a method to loop through lots of MXDs and fix the datasources from relative paths to UNC paths.
JeffMatson
Here is some old code from 10.3, you can use IMapAdmin2:
If newFC IsNot Nothing Then
featureLyr.FeatureClass = newFC
Dim mapAdmin2 As IMapAdmin2 = map
mapAdmin2.FireChangeFeatureClass(ds, newFC)
m_bSetDirty = True
End If
DuncanHornby
MVP Notable Contributor
I think to get to the bottom of this you need to show the full code, how you get a handle on the MXD, how you get a handle on the layers in the TOC, your update code and then when you save it. It's not clear where your checking code above is run.
Also looking at IDataSourceHelperLayer.FindAndReplaceWorkspaceNamePath why are you not setting the final parameter to TRUE to validate? Never used this interface so unsure what happens if validation fails.
JeffMatson
m_bSetDirty = True
End If
