Custom basemap not displaying via web link
931
09-12-2018 06:41 AM
BrandonBatt1
Using Survey123 Connect, is there a way to set a custom tiled basemap that will display if the user accesses the published survey via the web link?
We've followed instructions for modifying the .info file (json) and the survey displays when accesses through the Survey123 native (iOS or Android) app. The web link, however, just shows default basemaps when the survey is accessed via browser.
If we publish the survey through the web form (not Survey123 Connect), we can set a custom default basemap so long as we place a custom published tile map in our AGO Basemaps folder. Unfortunately, this approach doesn't seem to work through Survey123 Connect. Is there a way around this through Survey123 Connect?
Tags (3)
JamesTedrick
Esri Esteemed Contributor
Hi Brandon,
Currently, you cannot specify the basemap in the web map using the same setting as in the mobile app. I've added your request to the internal enhancement discussion on map selection.
BrandonBatt1
Thanks James!
