Using a Custom Geocoder
2414
09-07-2018 09:43 AM
ScottGeis1
In NYS we have a custom ESRI geocoding service that can geocode to rooftop level accuracy, and I am trying to use for batch geocoding in a Jupyter notebook using python.  However when I attempt to perform a batch_geocode operation I am not convinced that the address is being sent to the NYS service rather than the ESRI universal geocoding service.  Here is my code:
In [1]:   # Import the necessary libraries
            from arcgis.gis import GIS
            from arcgis.geocoding import Geocoder, get_geocoders, batch_geocode, geocode
In [2]:   #Set custom ESRI geocoding service url to the NYS Geocoding Service
            nys_gcdr_url = 'Locators/Street_and_Address_Composite (GeocodeServer) '
In [3]:   #Establish my connection to ArcGIS Online and set the preferred geocoder to the NYS geocoder
            gis = GIS("http://www.arcgis.com", "username", "password")
            esrinl_geocoder = Geocoder(nys_gcdr_url, gis)
            esrinl_geocoder
Out [3]:   <Geocoder                url:"https://gisservices.its.ny.gov/arcgis/rest/services/Locators/Street_and_Address_Composite/GeocodeSer...                r">
In [4]:   addresses = ["80 South Swan Street, Albany, NY, 12201",
                                 "10 B Airline Drive, Albany, NY, 12205",
                                 "800 North Pearl Street, Albany, NY, 12204",
                                 "5826 Fayetteville Rd, Durham, NC 27713"]
In [6]:     results = batch_geocode(addresses, esrinl_geocoder)
In [7]:      for result in results:
                     print("Score " + str(result['score']) + " : " + result['address'])
Out [7]:
Score 99.52 : 80 S Swan St, Albany, New York, 12210 Score 100 : 10 Airline Dr, Albany, New York, 12205 Score 100 : 800 N Pearl St, Albany, New York, 12204 Score 100 : 5826 Fayetteville Rd, Durham, North Carolina, 27713
In [8]:       results[1]['location']
Out [8]:    {'x': -73.81899493299994, 'y': 42.73686765800005}
My issue...
From what I can gather, the gis = GIS() in Input [3]: establishes a connection to ArcGIS Online using my developer account credentials.  Even though I set the Geocoder to the NYS geocoder url with esrinl_geocoder, I’m wondering which geocoder is actually being used?  The results/scores I output in the code are higher than I expect them to be, for example I get a score of 95.0 when I run the first address against the NYS geocoder here (Find Address Candidates: (Locators/Street_and_Address_Composite) ).  Also the x,y for the address vary based on method:
{'x': -73.81899493299994, 'y': 42.73686765800005} for ESRI Python and
{'x': -73.75989873712614, 'y': 42.654069473771784} for NYS Geocoder
In addition, the North Carolina address should not provide a match against the NYS geocoder, however it returns a score of 100 in Out [7].
So:
1) Does the batch_geocode operation default to the ESRI Geocoder despite the custom geocoder url being set with esrinl_geocoder?
2) Are there certain circumstances when this occurs, such as the ESRI geocoder kicks in when a match cannot be returned with the specified geocoder (e.g.; NC address)?
Thanks for any insight!
Tags (1)
MichaelVolz
Esteemed Contributor
Can you use Fiddler software against Jupyter notebook to see the url of the geocode service that is being called when retrieving the NC address?
ScottGeis1
I found my error.  Thanks to the code documentation at Understanding geocoders | ArcGIS for Developers I found I had a missing component where I called the geocode function. The Code should be as follows...
In [2]:   #Log into ArcGIS Online with user credentials
In [3]:   #Set custom ESRI geocoding service url to the NYS Geocoding Service
            nys_gcdr_url = "Locators/Street_and_Address_Composite (GeocodeServer) "
In [4]:   #Set esrinl_geocoder to the NYS geocoder
            esrinl_geocoder = Geocoder(nysGeocoderUrl, gis)
In [5]:   #Provide batch addresses
In [6]:     #This is where I was missing code, I need to set the geocoder function to the esrinl_geocoder
               results = batch_geocode(addresses, geocoder = esrinl_geocoder)
               results
               #Now I see the results I was expecting with the NC address results empty
Out [6]:
[{'address': '80 S Swan St, Albany, NY, 12210',   'location': {'x': 601644.6007360676, 'y': 4723145.388080139},   'score': 95,   'attributes': {'ResultID': 0,    'Loc_name': '1A_SAM_AP_ZipN',    'Status': 'M',    'Score': 95,    'Match_addr': '80 S Swan St, Albany, NY, 12210',    'Side': '',    'SubAdd': '',    'User_fld': '1',    'Addr_type': 'StreetAddress'}},  {'address': '10 B Airline Dr, Albany, NY, 12205',   'location': {'x': 596835.2465288276, 'y': 4732027.504390771},   'score': 100,   'attributes': {'ResultID': 1,    'Loc_name': '1A_SAM_AP_ZipN',    'Status': 'M',    'Score': 100,    'Match_addr': '10 B Airline Dr, Albany, NY, 12205',    'Side': '',    'SubAdd': '',    'User_fld': '1',    'Addr_type': 'StreetAddress'}},  {'address': '800 N Pearl St, Albany, NY, 12204',   'location': {'x': 603476.4214812117, 'y': 4726078.037474971},   'score': 100,   'attributes': {'ResultID': 2,    'Loc_name': '1A_SAM_AP_ZipN',    'Status': 'T',    'Score': 100,    'Match_addr': '800 N Pearl St, Albany, NY, 12204',    'Side': '',    'SubAdd': '',    'User_fld': '1',    'Addr_type': 'StreetAddress'}},  {'address': '',   'location': {'x': 'NaN', 'y': 'NaN'},   'score': 0,   'attributes': {'ResultID': 3,    'Loc_name': '',    'Status': 'U',    'Score': 0,    'Match_addr': '',    'Side': '',    'SubAdd': '',    'User_fld': '',    'Addr_type': ''}}]
In [7]:      #Another way to visualize this
         Score 95 : 80 S Swan St, Albany, NY, 12210          Score 100 : 10 B Airline Dr, Albany, NY, 12205          Score 100 : 800 N Pearl St, Albany, NY, 12204          Score 0 :
