Append gives a empty string error
2490
6
09-07-2018 07:32 AM
DougBrowning
MVP Esteemed Contributor
had to delete
JoshuaBixby
Did your code get cut off?  For one, I don't see a try statement anywhere in what you posted.  Also, there is no text below "Error is".
DougBrowning
yea just a part of the code - its 300 lines...
Yes the error is blank - that was the whole point of my post.  It works yet fails with error text of ''.
thanks
JoshuaBixby
You state the "tool trips the try statement," but I don't see any try statement in what you posted.  If the code you posted is the working code, then I suggest you post the code that generates the error if it is the error you are trying to get feedback on.
DougBrowning
Umm ok I added a try.  Not sure why that matters.  I cant post all 300 lines.
Really just asking if anyone has gotten a blank error on Append.
thanks
DarrenWiens2
Unless you specifically ask for the exception, the error message won't be displayed - that's the point of try/except:
foo = 'a'
bar = 1
try:
    concat = foo + bar
except Exception as e:
    print(e)‍‍‍‍‍‍
must be str, not int‍‍‍‍‍‍‍‍
Of course, you may have this, but we can't see your try/except statement.
DanPatterson_Retired
Of course, skipping the try except block reveals the same message.
Only use them if you know you are going to get an error message that would be thrown that isn't a python error or you want to do something else if there is an error.
foo = 'a'
bar = 1
concat = foo + bar
  File "<ipython-input-56-ef8dcb5742bb>", line 1, in <module>
    concat = foo + bar
TypeError: must be str, not int
a better non-fail
try:
    concat = foo + bar
except:
    concat = "{}{}".format(foo, bar)
concat
'a1'
