FGDB - Error when writing unicode into blob field
1539
09-07-2018 05:25 AM
MaximeDemers
I got an SystemError : error return without exception set error when trying to write a unicode into a blob field into a table inside a FGDB using arcpy.da.UpdateCursor with ArcGIS v10.3
for instance:
import arcpy
value = u"a unicode string! with some accent éàèû"
with arcpy.da.UpdateCursor(r"c:\\my_fgdb.fgdb\my_table", ["blob_field"], where_clause="FID = '0') as cursor:
    for row in cursor:
        row[0] = value
        cursor.updateRow(row)
I know blob can store string, but is it normal it cannot store unicode?
JoshuaBixby
MVP Esteemed Contributor
Since ArcGIS Desktop/ArcMap uses Python 2.x, inserting or updating a Blob field with a Python str object works because str is a sequence of bytes.    A Unicode string is a sequence of Unicode code points, not bytes.  Since a Blob field is designed to store binary data, you can't directly insert or update a Blob field with a Python Unicode string.  If you want to work with Unicode strings in Blob fields, you will need to encode and decode the strings first.
import arcpy
    for row in cursor:
        row[0] = value.encode('utf8')
JoshuaBixby
import arcpy
    for row in cursor:
MaximeDemers
Hello Joshua,
Thank you for the information about the blob field!
Do you have an idea why storing unicode in text field works?
JoshuaBixby
The ArcGIS Text field is actually Unicode:  ArcGIS field data types—ArcGIS Help | ArcGIS Desktop
The characters used for text vary by language. To allow text to more easily convert between languages, ArcGIS uses Unicode to encode characters.
