select_one selection calculations
957
09-04-2018 01:49 PM
deleted-user-8TVt6oc0ewsX
I have a form with a select_one, some text fields (data entry)  and some pulldata() text fields.  If I enter data into one of the text fields all the pulldata() calculations are performed.  I cannot get the select_one to perform the pulldata() calculations.  Is there a trick to getting the pulldata() calculations to perform when someone makes a select_one selection?
BrandonArmstrong
Hi Jonathan,
I have attached an example of a pulldata calculation working against a choice from a select_one question.  Please take a look and see if this is helps you.  If this does not help you, please provide the zipped folder as an attachment to this thread, or I can provide you with my email upon request.
Best,
Brandon
Thanks, this is exactly what I needed.  I had my CSV incorrectly formatted.  I want to allow the user to pick from a list if a barcode read doesn't work.  Should I be able to conditionally do a PULLDATE() using IF...THEN?  IF barcode is NULL then pulldata() using select_one?
