Image field not showing - when editing
1228
08-28-2018 07:40 AM
RobertMEIER
I have a survey with a number of image fields that work, regardless of whether I am collecting new or editing data.
I just added 2 new image fields and when editing, the label is the only thing that appears in the survey. But when collecting new data, I see the label and the icons for taking a photo or uploading.
I have tried moving the new image fields around in the survey, into a group, copying an image field that is working, deleting, publishing, then adding back and publishing, I even looked at the xml to see if there was anything in there that looked odd.
Nothing is working.
Has anyone experienced this behavior?
Thanks!
-bert
JamesTedrick
Esri Esteemed Contributor
Hi Bert,
Currently, Survey123 does not support editing attachments (including images) at this time.
RobertMEIER
Sorry, I am not being clear enough. These are not existing attachments.
The survey I am creating uses the inbox to "edit" existing data. I added some image questions to other parts of the survey and they operate correctly in the app.
But I went in this morning and added two other image questions and they do not seem to work. I see the label in the app but not the camera or file icons.
JamesTedrick
Hi Bert,
Adding attachments as part of the editing process is not supported (it's encompassed as part of editing attachments).
