Moving web AppBuilder app from test to prod - external data source
1409
08-24-2018 11:02 AM
OfraAinemer
Many times I move apps between environments, I update the web map id (config.json => itemid), and find-replace all rest url's (notepad++ is great for that).
Now I've used external data source in the app. These sources are from the same web map used in the app. I use them in InfoGraphic widgets#.
The migrated app shows "No data" for all these widgets.
What should I change in order to reconnect to the external data source?
I do not have dev edition in the production environment...
I'll appreciate any help.
Ofra
RobertScheitlin__GISP
Ofra,
  if you have updated the external data souces in the main config.json then you may need to update the apps/configs/Infographic/config__##.json file
OfraAinemer
Thanks Robert,
I've found in the main config file and the widgets config files something like LayerID~numbers
The layer Id is taken from the web map.
I've changed the layer id in all those config files to the same layer id I found in the new web map (using portal/sharing/rest/content/item/[webmapID]/data...).
I still get "no data".
Any thing else I should change?
Ofra
Ofra,
  That is all that I am aware of.
OfraAinemer
Thanks.
At the end, I've installed the dev environment and put the app in it. When I've checked the external data source definition - everything reconnected and worked fine, without any change. Kind of "refresh".
Ofra
