add one feature class to one mxd arcpy
2686
8
08-24-2018 04:12 PM
LETITIAKING-BRANCH
Hello
I'm trying to create one mxd for each for layer from an existing MXD.  I have list of layers in a mxd but  I want  one mxd to one layer.  This is the script I've been using. It copies all of the layers to the new mxd.
import arcpy
... mxd = arcpy.mapping.MapDocument("CURRENT")
... for df in arcpy.mapping.ListLayers(mxd):
          df.name
          mxd.saveACopy(r"C:\Project\Output\\" + df.name + ".mxd")
... del mxd
DanPatterson_Retired
All the layers in the dataframe will be there by default.  In order to do what you want to do, you would have to add a layer, save it out, remove the layer, add a new one and repeat.
What is the purpose of having one mxd that only contains 1 layer? Perhaps other solutions can be provided that would meet your goals
LETITIAKING-BRANCH
The purpose of having one mxd for one layer is to create a service for each route layer for ArcGIS online.  This will used to display each individual bus route.  Thanks
Ahhhh… I will share to ArcGIS Online‌ … it didn't quite make sense for just working with arcmap or Pro unless you were making personalized lab assignments (each student... different data)
JoshuaBixby
MVP Esteemed Contributor
You would need to create an empty MXD to use as a template for inserting each layer into a new, empty map document:
import arcpy
mxd_empty = # path to empty mxd
for lyr in arcpy.mapping.ListLayers(mxd):
    mxde = arcpy.mapping.MapDocument(mxd_empty)
    dfe = arcpy.mapping.ListDataFrames(mxde)[0]
    arcpy.mapping.AddLayer(dfe, lyr)
    mxde.saveACopy(r"C:\Project\Output\\" + lyr.name + ".mxd")
del lyr, mxd, dfe, mxde
LETITIAKING-BRANCH
I'm getting runtime error Invalid mxd filename
>>> import arcpy
... mxd_empty = "c:\project\Output"
... for lyr in arcpy.mapping.ListLayers(mxd):
...     mxde = arcpy.mapping.MapDocument(mxd_empty)
...     dfe = arcpy.mapping.ListDataFrames(mxde)[0]
...     arcpy.mapping.AddLayer(dfe, lyr)
...     mxde.saveACopy(r"C:\Project\Output\\" + lyr.name + ".mxd")
... del lyr, mxd, dfe, mxde
Runtime error
  File "<string>", line 7, in <module>
  File "c:\program files (x86)\arcgis\desktop10.6\arcpy\arcpy\arcobjects\mixins.py", line 651, in __init__
    assert (os.path.isfile(mxd) or (mxd.lower() == "current")), gp.getIDMessage(89004, "Invalid MXD filename")
AssertionError: Invalid MXD filename.
you see to be mixing raw and double backslash formatting.
You might want to print the layer name prior to concatenating to see what it is showing
r"C:\Project\Output\\"   should be r"C:\Project\Output\"
LETITIAKING-BRANCH
Now I'm getting
 >>> import arcpy
... mxd_empty = "C:\Project\Output"
...     mxde.saveACopy(r"C:\Project\Output\" + lyr.name + ".mxd")
Parsing error SyntaxError: EOL while scanning string literal (line 10)
LETITIAKING-BRANCH
  I had to include the actually empty. mxd in the path not just the directory.  Thanks Josh
import arcpy
... mxd_empty = "c:\project\output\empty.mxd"
