Display results/layers in Spyder Jupyter Notebook
4405
7
08-17-2018 12:20 PM
ZacharyHart
Honored Contributor
Is there a way to visualize query results (like a Query Table or layer) in either of these IDE's? I know you can leverage the arcgis module in Jupyter, but here you're beholden to a web GIS. What if you're just running queries against an SQL instance? I really like both of these IDE's but at least if you're using the ArcGIS Python window (Dan Patterson‌ don't shoot me!) you see your results displayed directly (as a table or layer).
Any thoughts? Maybe I'm missing something really obvious here.
Thanks!
DanPatterson_Retired
import arcpy
f = r"C:\Git_Dan\JupyterNoteBooks\Data\Shapefiles\test.shp"
a = arcpy.da.TableToNumPyArray(f, "*")
sub = a[(a['FID'] > 2) & (a['C'] < 10)]
frmt_rec(sub)
--n-- FID     Shape       C       D       E       F       G       H       I       J       K       L
 000    3   [4. 9.]    7.62    8.94    8.25    0.00    4.47    3.16    2.24    5.83    8.54    7.28
 001    4   [0. 7.]    8.60   10.00    6.32    4.47    0.00    1.41    5.00    7.62    6.08    5.39
 002    5   [1. 8.]    8.49    9.90    7.07    3.16    1.41    0.00    4.12    7.21    7.00    6.08
 003    6   [5. 7.]    5.39    6.71    6.71    2.24    5.00    4.12    0.00    3.61    7.21    5.83
 004    7   [7. 4.]    2.00    3.16    5.83    5.83    7.62    7.21    3.61    0.00    6.71    5.39
 005    8   [1. 1.]    6.08    7.00    1.00    8.54    6.08    7.00    7.21    6.71    0.00    1.41
 006    9   [2. 2.]    5.00    6.08    1.00    7.28    5.39    6.08    5.83    5.39    1.41    0.00
You can always query the results and convert the table to a numpy array using.
If you are nice I will even share my fancy formatting function
Done in Spyder
https://community.esri.com/ideas/15429
ZacharyHart
Honored Contributor
Dan,
that makes good sense and is very helpful!
Maybe for a bit of context, as a novice python user, I hack my way towards creating things I need to get done. Even with all the shortcomings of the python window in ArcGIS, I'll often use that to bash away at various tools and I'll have an immediate idea (a visualization of the output) if they're gonna work or not. If one was to say try to figure out SelectLayerByLocation_management, you could do so and see  your results right away and then build that into a tool/script/function.
I'm loving Jupyter & Spyder, (especially given my envy every time a colleague shows me what they're doing in R-Studio [but let's not start the Rodeo debate, right?]). I know I can't get the visualization end of things in Jupyter using our web GIS, but that's not what I'm trying to achieve here.
Maybe I'm just having a Goldilocks moment and want the perfect thing? Anyway, hopefully the background is helpful, but maybe what i'm looking for just doesn't exist outside ArcGIS.
Thanks!
I just use the code snippets in the help file, if needed.
This just saves the expression which is pretty useless...
Now the selection works
so you go here
and copy the python command and … voila!
arcpy.management.SelectLayerByAttribute("a_1_pnts", "NEW_SELECTION", "OBJECTID < 8 And grid_code = 2", None)
ZacharyHart
Honored Contributor
Thanks Dan. I have used python snippets in the past as a learning tool.
Let me try to explain a little further. One of the redeeming qualities of using the python window in ArcGIS is that you are able to see your results, and therefore know that the command you executed works. Instant feedback.
yes... good for snippets or one liners but you do get feedback in spyder if you make a mistake... you just have to know what they mean.
Use all!  I usually have 2 IDE's open but not that sad arcmap python window (but that is another story)
ZacharyHart
Honored Contributor
Solid advice...thanks!
KyleGonterwitz
Try importing pandas and using df = pd.DataFrame.from_records(data=arcpy.da.SearchCursor(fc,fields),columns=fields)
where fc is your GIS feature class layer and fields are a list of fields in fc you define
format the data frame and print tables, display tables, or display(HTML(table.to_html())) for larger outputs
try using group by with .sum or .apply and lambda functions for fast results printed in the jupyter output window
