Error converting Json file to a feature class
11774
7
08-20-2018 06:55 AM
JustinBridwell2
I want to convert some json data being returned from a request to a feature class, but I keep getting a RuntimeError: Object: Error in executing tool. I made a test gdb in a folder 'C:/Workspace/Sandbox/ScratchTests/cslf.gdb' in which to populate my new feature class after conversion. To test that the request is correct and that I am returning Json data, I added a couple of print statements. Otherwise, everything is pretty straight forward. Does anyone see a problem with my code? I am following the arcpy [JSON to Features][1] directions from the documentation. The only thing I am doing differently is instead of using an actual file, I am just plugging in the variable 'cslfJson`.
import arcpy, sys, os, arcgis, requests
arcpy.env.workspace = "C:/Workspace/Sandbox/ScratchTests"
params = {'f': 'json', 'where': '1=1', 'geometryType': 'esriGeometryPolygon', 'spatialRel': 'esriSpatialRelIntersects','outFields': '*', 'returnGeometry': 'false'}
r = requests.get('https://hazards.fema.gov/gis/nfhl/rest/services/CSLF/Prelim_CSLF/MapServer/3/query', params)
print(r.url)
cslfJson = r.json()
print(cslfJson)
arcpy.JSONToFeatures_conversion(cslfJson, os.path.join("cslf.gdb", "cslf"))
JoshuaBixby
MVP Esteemed Contributor
Besides the missing geometry that Randy Burton‌ pointed out, your code isn't going to work because JSON To Features—Conversion toolbox | ArcGIS Desktop requires a "JSON file", not JSON text or some kind of JSON object.
Syntax
JSONToFeatures_conversion (in_json_file, out_features, {geometry_type})
ParameterExplanationData Type
in_json_file
The JSON file (.json) to convert.
File
out_features
The output feature class to create.
Feature Class
geometry_type
(Optional)
The geometry type to convert from GeoJSON to features. This option is only used when the input is a GeoJSON file. If the GeoJSON file does not contain any of the selected geometry type, the output feature class will be empty.
  • POINT Convert any points to features.
  • MULTIPOINT Convert any multipoints to features.
  • POLYLINE Convert any polylines to features.
  • POLYGON Convert any polygons to features.
String
It would be great if Esri support in-memory streams (e.g., io.SteamIO) in addition to files, but I am not holding my breath.  In the meantime, you have to dump the JSON results to a text file and then pass that file to the conversion tool.
I get a sense there is a more straightforward way of going about this using the ArcGIS API for Python, but I would need some more information before suggesting anything specific.
RandyBurton
Can you provide the complete error message?
JustinBridwell2
Here's the traceback:
File "<ipython-input-21-7d5d88079864>", line 1, in <module>
runfile('C:/Workspace/Sandbox/ScratchTests/CSLF.py', wdir='C:/Workspace/Sandbox/ScratchTests')
File "C:\Users\jbridwell\AppData\Local\Continuum\anaconda3\envs\acrpro\lib\site-packages\spyder_kernels\customize\spydercustomize.py", line 668, in runfile
execfile(filename, namespace)
File "C:\Users\jbridwell\AppData\Local\Continuum\anaconda3\envs\acrpro\lib\site-packages\spyder_kernels\customize\spydercustomize.py", line 108, in execfile
exec(compile(f.read(), filename, 'exec'), namespace)
File "C:/Workspace/Sandbox/ScratchTests/CSLF.py", line 20, in <module>
arcpy.JSONToFeatures_conversion(cslfJson, os.path.join("cslfalso.gdb", "cslf"))
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\conversion.py", line 403, in JSONToFeatures
raise e
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\conversion.py", line 400, in JSONToFeatures
retval = convertArcObjectToPythonObject(gp.JSONToFeatures_conversion(*gp_fixargs((in_json_file, out_features), True)))
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 506, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
RandyBurton
And when you print(cslfJson), does it appear to be correctly formatted json and a feature?
JustinBridwell2
Yep. You can actually try it yourself with the code above. Thats a public Map service from fema. Just import requests, json and the rest of the code (except arcpy.env.workspace) down to print(cslf). It should work the same for you as me.
RandyBurton
I hit a timeout on my data request, so there are a lot of records; the json indicated: "exceededTransferLimit": true with perhaps 1,000 records returned.  You may need to do something to limit your query results.
I also noticed that you are not requesting the geometry ( 'returnGeometry': 'false' )  which would cause JSONToFeatures to fail.  You should see something like this in your json:
   "geometry": {
    "rings": [
       -9165686.7350331135,
       3936948.9098836873
       -9165681.1218573805,
       3936946.988356465
       -9165681.5995294657,
       3936947.138881634
       3936948.9098836873
JoshuaBixby
Syntax
in_json_file
File
out_features
Feature Class
geometry_type
(Optional)
String
Juan_JulioLiñan_rebaza
Hi Justin, as Joshua pointed out, try to have the json file before run the tool. May be this could help you.
import arcpy, sys, os, arcgis, requests, json
#Create a route to store your json file
jsonFile="C:/Workspace/Sandbox/ScratchTests/jsonTest.json"
print(r.url)
cslfJson = r.json()
print(cslfJson)
#Pass the request to a jsonfile
with open(jsonFile,'w') as jsonDir:
   json.dump(cslfJson,jsonDir)
arcpy.JSONToFeatures_conversion(jsonFile, os.path.join("cslf.gdb", "cslf"))‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
