What is the best method to load multiple feature classes into AGO?
1213
08-16-2018 11:37 AM
AnnVanSlembrouck
Do I need to zip up each as a separate shapefile or can I add multiple to a file geodatabase then zip that up?
Tags (1)
MarisaClaggett
Hi Ann,
You are correct.  The easiest way to add multiple layers as an item to AGOL would be to add them to a file geodatabase and zip it up.
What can you add to ArcGIS Online?—ArcGIS Online Help | ArcGIS
Best,
Marisa
XanderBakker
Esri Esteemed Contributor
I would prefer to use the share option in ArcGIS Pro (or ArcMap). Introduction to sharing web layers—ArcGIS Pro | ArcGIS Desktop
