v3 is evaluating constraints on fields that are not relevant yet
806
08-16-2018 10:38 AM
DougBrowning
MVP Esteemed Contributor
I have a form that was in use for 6+ months now without issue.  I updated to v3, made a small change and republished.  The form then suddenly starting stopping submissions giving a error that a constraint was being broken, on a field that was not even relevant at the time and the user cannot even see.  I had to add "" empty string now to the constraint to get around it.  Always worked as designed before.
Is this a new bug?  Why would a constraint be checked on a non-relevant field?
thanks
JohnathanHasthorpe
Hi Doug
Are you able to share your survey xls? I'll take a look.
John
