Send Error
2297
08-13-2018 07:35 AM
CarlHolt1
Send Error (no code) when users attempt to submit a specific survey.
Send Error
If I sign in as Admin, I can send the survey. Same error if users are on LTE or WiFi.
Survey123 submitter settings:
Users are able to successfully submit other surveys.
IsmaelChivite
Esri Notable Contributor
Thanks Carl.To close this thread: Carl and I looked at the survey in more detail and realized that the permissions on the feature layer had been modified unintentionally, revoking permissions on end-users to add new features. After putting back permissions into the feature layer, Survey123 was able to submit as usual.
I added a note in our backlog indicating in what conditions the feature service error description is blank. We will investigate why this is the case.
IsmaelChivite
Hi Carl.
Can you attach your XLSForm?
CarlHolt1
I also get a message about updating links
IsmaelChivite
