Hello! I have used the storage migration tool in ArcMap, to modify the keyword a feature class.
I have some doubts 1) It is possible to migrate from ST_GEOMETRY to SDO_GEOMETRY? 2) He observed that when carrying out the storage migration for example from
SDO_GEOMETRY to ST_GEOMETRY in the properties of the feature class and in the schema of the
owner of the data if the modification appears, but the TABLE_REGISTRY of SDE does not modify
the field of CONFIG- KEYWORD
As for going from ST_Geometry --> SDO_Geometry, that cannot be done via the Migrate Storage—Help | ArcGIS Desktop tool; Data migration from one storage type to another—Help | ArcGIS Desktop
You mention that you have run the Migrate Storage tool; what where the parameters that you place in the GP tool?
Can you provide clarification on the following statement?
