ArcPy loop not saving rasters
2603
08-10-2018 02:11 PM
JoelSalzman
I'm trying to do Map Algebra on a bunch of rasters by iterating through a for loop and saving them in an empty geodatabase. However, they aren't saving properly. Only the last raster is created and it is named "rescaledRaster" rather than the outName. Here's the code:
import arcpy, os
from arcpy.sa import *
arcpy.env.workspace = r"[abspath]"
arcpy.env.scratchWorkspace = r"[abspath]\rescale.gdb"
aprx = arcpy.mp.ArcGISProject(r"[abspath]\filename.aprx")
# Select correct interpolated rasters
for lyr in aprx.listMaps()[0].listLayers():
        if lyr.isRasterLayer:
                if 'Temp' in lyr.name:
                        if 'Int_Raster' in lyr.name:
                                # Set local variables
                                raster = Raster(lyr.dataSource)
                                thresholds = [14, 23]
                                bounds = [14, 23]
                                scale = [1, 0.496714]
                                transformation = TfLinear( bounds[0], bounds[1], thresholds[0], 1, thresholds[1], 0 )
                                outName = arcpy.env.scratchWorkspace + "\\" + raster.name.replace('Int_Raster','Resc')
                                # Rescale the raster
                                rescaledRaster = RescaleByFunction( raster, transformation, scale[0], scale[1] )
                                # Save the rescaled raster
                                rescaledRaster.save(outName)    #NOT WORKING!!!
                                print(rescaledRaster.isTemporary)
                                print(rescaledRaster.name)
The print statements seem correct each time; .isTemporary comes out False and .name returns the outName. Despite this, the output rasters keep getting overwritten.
I also tried outName = os.path.join(arcpy.env.scratchWorkspace, raster.name.replace('Int_Raster','Resc')) as well and that didn't work either.
DanPatterson_Retired
save is not saving the 'raster', you should be saving 'rescaledRaster'
rather than trying to fiddle around with the name before you process it... rename it after it is saved
Rename—Data Management toolbox | ArcGIS Desktop
JoelSalzman
Am I not already saving 'rescaledRaster' with rescaledRaster.save(outName)? I've tried the following as well, which is what I think you're suggesting:
name = inRaster.name.replace('Int_Raster','Resc')
rescaledRaster.save()
arcpy.Rename_management(rescaledRaster, name)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
I've done it with and without the following addition beforehand, as per this thread.
arcpy.env.overwriteOutput=True
if arcpy.Exists(outName):
        arcpy.Delete_management(outName)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
I get the following error message regardless:
arcgisscripting.ExecuteError: ERROR 999999: Error executing function.
The table already exists. [name]
Failed to execute (Rename).‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
("name" is the actual name, not the variable). I cannot do
arcpy.Rename_management(rescaledRaster, outName)‍‍‍‍‍
 or else I get this:
ERROR 000670: output Output Data is same as input Input Data Element
Throw in some print statements to make sure that the name is correct. I can't tell from the code
SharolynAnderson1
Hello All -- I still have the same problem and wondering if anyone has solved the issue with .save throwing the RuntimeError: ERROR 999998: Unexpected Error..
