Choosing a feature and selecting by attributes using arcpy
4069
08-01-2018 01:54 PM
JustinBridwell2
Hey All- Let's says I have a list of state Names in a Python script:
stateNames = ['Alabama', 'California', 'Colorado', ...]
I also have a gdb called states.gdb, that has a feature for each state: Alaska, Alabama, California, etc...
I also have an attribute value that I want to use to select certain features by attribute. Lets say its 'Fips_code' = 01007.
Using an item from my stateNames list, lets use stateNames[0] or Alabama, I want to get the Alabama feature from my states.gdb and select all of the records that have have Fips_code = 01007. Any suggestions on where to begin?
DanPatterson_Retired
Select Layer By Attribute—Data Management toolbox | ArcGIS Desktop
You can do it manually and save the expression, then use it by modifying the code snippet in the help.
In your case, query the states field for Alabama 'And' the FIP's field equal to your value
