Layer cannot be updated to HTTPS?
1321
08-01-2018 06:59 AM
by Anonymous User
Not applicable
Having an issue with Update Layers to HTTPS in ArcGIS .   So in settings for our webmaps there is the option to Update Layers to HTTPS.  We recently installed a certificate on the server signed by a Trusted Authority in order for our maps to work in all browsers without loading unsafe scripts or mixed content errors.
When I add our HTTPS (6443) layers to webmaps using the Add Layer from Web they work just fine.  However if I use the Update Layers to HTTPS in Settings for the webmap I receive this error.
I'm in the process of changing all of our layer references in webmaps to HTTPS and want to make sure I'm not missing anything.  Will I have to go in to every web map and manually add each layer with is secure REST service address using Add Layer from Web and remove the old ones?
by Anonymous User
Not applicable
I realized I can Update Site References and replace the http://(server):6080 to be https://(server):6443 and that worked.  I still don't understand why the Update Layers to HTTPS is not working properly.
irtizahussain
Gabriel, how you update http to https? is this working fine now!!
