Apply Asset Package Script Tool Error
4715
10
07-31-2018 11:42 AM
MarkCederholm
I'm going through the Naperville Gas utility network walkthrough, and when I tried to run the untools Apply Asset Package tool, I got the following error:
File "untools\utils\schema_package.py", line 811, in _validate_associations_have_rules
rules = rules.append(junction_rules, sort=False)
TypeError: append() got an unexpected keyword argument 'sort'
After I commented out the "sort" keyword on line 811, the tool ran fine.
MikeMillerGIS
Esri Frequent Contributor
To add to Paul's response.  The tool is expecting pandas .23 or higher.  At .23, a new keyword was added.  If you installed something in python that downgraded your pandas version, you will experience this issue.  You can wait for the updated set of tools which will require >.23 or you can upgrade your version through conda.
Here is some information on the change to pandas:
https://pandas.pydata.org/pandas-docs/stable/whatsnew.html#concatenation-will-no-longer-sort
See the note that append also received the sort keyword
HungTruong
Do you have the latest updates of Pro and 10.6.1 Enterprise?
MarkCederholm
Yes.  Latest version of everything.  Which leads me to think that a recently developed flaw slipped through the cracks after the documentation was published.
HungTruong
I cannot re-produce the error, the Apply Asset Package worked well for me. Here is my configuration:
ArcGIS Pro 2.2.0
untools 2.2
ArcGIS Enterprise 10.6.1
Gas Asset Package (released June 25, I guess, the latest one)
You may need to check the verion of untools you are using, make sure it is the version 2.2
MarkCederholm
I'm the same, except that Pro is 2.2.1.  That shouldn't make any difference?
AnthonyRyanEQL
Mark,
I think Patch 1 for Pro 2.2 could be an issue. I’m having issues with the deployment adding in trying to download the pro package to 10.6.1 portal and agol. all works fine without the patch applied. i have someone in esri inc looking at it now
HungTruong
No, it's not. Pro 2.2.1 works as well, I've just tested it
PaulLeBlanc1
We'll be releasing untools 2.2.1 in the next few days that will pin the dependency of pandas.
For more information: What’s New — pandas 0.23.4 documentation
MikeMillerGIS
MarkCederholm
Finally, a reply that makes sense to me.  I followed the disconnected installation because my corporate firewall is a son-of-a-b**** and so I wouldn't be surprised if I missed a requirement.
