How do I copy a geodatabase to a different location using arcpy?
8695
5
07-30-2018 03:03 PM
by Anonymous User
Not applicable
I'm wanting to make a copy of a geodatabase from one location on our network to another. Can anyone help?
by Anonymous User
Not applicable
Thanks for the help. Below is my final script I came up with that has been tested and works.
import arcpy
from arcpy import env
env.workspace = r"M:\GIS Geodatabases"
arcpy.Copy_management("Cadastral.gdb", r"T:\pl\Planning Geodatabases\Cadastral.gdb")
print "Cadastral.gdb Copy Complete"
arcpy.Copy_management("Transportation.gdb", r"T:\pl\Planning Geodatabases\Transportation.gdb")
print "Transportation.gdb Copy Complete"
arcpy.Copy_management("AdminBoundaries.gdb", r"T:\pl\Planning Geodatabases\AdminBoundaries.gdb")
print "AdminBoundaries.gdb Copy Complete"
JoeBorgione
I started writing out some code, but check this: Copy—Help | ArcGIS Desktop   it's pretty easy...
by Anonymous User
Not applicable
import arcpy
JoeBorgione
Good job; you only need to set your workspace once, so lines 10 & 14 aren't needed. If you want to have some fun, create a list of the the database names and iterate through them in a 'for' loop....
by Anonymous User
Not applicable
I'm pretty new to Python but thanks for the input. I will have to give that a try so I can sharpen my skills.
JoeBorgione
Stick with it and have some fun.  Anytime you need to do something more than a couple of times, script it.  There is only one way to get into python, and that's to get into python!  A year ago I couldn't spell python...
