Problem with boundary label placement
3121
6
07-26-2018 01:29 PM
MelissaJohnson
I am trying to label some polygons using boundary label placement with Remove Duplicate Labels set to Remove all.  For some reason ArcGIS Pro is not honoring the Remove Duplicates.  What I really want to accomplish is for a single label to be on each line in the middle of the line (as shown by the yellow highlight).  I know this was an option in ArcMap.  Any idea why it doesn't work in Pro?
DanPatterson_Retired
confused... is that image the one from Pro or the one from ArcMap?
MelissaJohnson
From pro.  That highlighted area is what I want the labels to look like, one label in the center of the line.  The south line is putting 3 repeating sets of labels and the east line is not centered which is what I want.  There is nothing there to interfere with the labels to prevent them from labeling correctly, I have turned everything else off.  The main thing is that they shouldn't be repeating at all having set them to remove all duplicates.
The south line looks like it has 3 segments, the east line... that is a weird one
MelissaJohnson
I guess I should note that this is a polygon layer I am working with.  I assumed it would label each side one time (I feel like this has worked for other projects before for me)  I think just converting the labels to anno and moving them manually is the only route.
ssbailey430
I see this post is from 2018, but I am still experiencing this problem with ArcGIS Pro 3.4.0. I am using Boundary Placement for a polygon layer for towns. I have Remove duplicate labels set to Remove All, but it only removes one set of labels. Using Remove within fixed distance doesn't do anything different either. Can someone explain why this is happening? I would rather not have to convert labels to annotation.
Oddly, the opposite problem is happening for labels with River Placement. Even though there are multiple lines with the same label, and Remove duplicate labels is set to Do not remove, only one label per stream shows up.
@Robert_LeClair
Robert_LeClair
Esri Esteemed Contributor
@ssbailey430 - are you able to send me a sample of the data so I may do some testing on my side?  If so, my email address is rleclair at esri dot com - thx!
