SelectFeature for a FeatureCollectionLayer?
1363
07-27-2018 12:37 PM
MikeBrown6
I have a collection of features that I create in code to mimic as if my data had a FeatureLayer. I have the Features properly showing up on the map and I can even identify the feature when tapped and output the data from the backing fields. However, I don't see any of the Select methods that are used in FeatureLayers. I prodded around and did find a hack to get to the method call:
var identifyResults = await MyMapView.IdentifyLayerAsync(MyFeatureCollectionLayer, tapScreenPoint, pixelTolerance, onlyReturnPopups, maximumResults);
var fcl = identifyResults.SublayerResults.FirstOrDefault();
if (fcl != null)
        foreach (Esri.ArcGISRuntime.Data.GeoElement idElement in fcl.GeoElements)
            Esri.ArcGISRuntime.Data.Feature idFeature = idElement as Esri.ArcGISRuntime.Data.Feature;
            //fcl.SelectFeature(idFeature); // No methods for selection!!!
            MyFeatureCollectionLayer.FeatureCollection.Tables[0].FeatureLayer.SelectFeature(idFeature);
            CalloutDefinition callout = new CalloutDefinition(idFeature.Attributes["Number"].ToString(), idFeature.Attributes["Location"].ToString());
            MyMapView.ShowCalloutAt(e.Location, callout);
However, if I get a reference to that FeatureLayer and try to perform the same IdentifyLayerAsync it won't return any results. Should/will FeatureCollectionLayers have a SelectFeature() method?  Am I using the wrong tooling (for adding POCO data to a map)? I had tried doing this with a GraphicsOverlay but ran into issues with interacting with the data -queries, filters, etc.
MaraStoica4
Hi Mike,
I ran your code with a couple of small modifications on a FeatureCollectionLayer I created and it selects without issues. See below please.
private async void MapView_GeoViewTapped(object sender, Esri.ArcGISRuntime.UI.Controls.GeoViewInputEventArgs e)
     // get reference to MapView
     var mapView = sender as MapView;
     // get the first operational layer in the map (I only added one layer so this should find the layer I'm looking for)
     var layer = mapView.Map.OperationalLayers[0] as FeatureCollectionLayer;
     // get the tap location in screen units
     var tapScreenPoint = e.Position;
     // set identify parameters
     var pixelTolerance = 100;
     var returnPopupsOnly = false;
     var maxResultCount = 5;
     if (layer != null)
          // call the identify operation
          var identifyResults = await mapView.IdentifyLayerAsync(layer, tapScreenPoint, pixelTolerance, returnPopupsOnly, maxResultCount);
          // get the layer containing the identify results
          if (fcl != null)
               // get every feature that was identified
                    var idFeature = idElement as Feature;
                    // select feature
                    layer.Layers[0].SelectFeature(idFeature);
MaraStoica4
Hi Mike,
     if (layer != null)
          if (fcl != null)
                    // select feature
