Select Widget check on layer visibility change
757
07-26-2018 01:34 PM
JaysonLindahl
Is there a way to get the Select Widget to act the way it does when it's initially activated?
By this I mean when you turn on a layer in your layer list to make it visible on the map, then activate the Select Widget, your layer will be black and contain a check-mark.  When you go back to your layer list and turn on another layer, then go back to the Select Widget, you layer will be black, but no check-mark will be in the box.
I'm using Web Appbuilder Dev 2.7
Tags (1)
