How to use Draw Map Extent to Export Map based on Users Drawing
2191
07-25-2018 10:24 AM
AaronPaul5
My goal is to provide Users the ability to draw a rectangle on a map to pass the extents back to export a .png of the extent drawn.
This would be done through a
I see potential in the Clip and Ship functionality where the User Draws a Rectangle to pass the top and bottom x,y values.
My script currently uses a County Layer to select 1 or 2 counties.
The code then zooms to selected features extent.
This is sort of hit an miss as the user needs to know what counties to select.
I want the user to draw extent instead.
In that case, the If statement would go away.
map_extent = parameters[0].valueAsText
map_extent2 = parameters[1].valueAsText
outfolder = arcpy.env.scratchWorkspace
mxd = r"\\Maps\MyMap.mxd"
if map_extent <> "Default Extent":
    expression = '"altName" IN' + " ('" + map_extent + "', '" + map_extent2 + "')"
    arcpy.AddMessage(expression)
    county_layer = arcpy.mapping.ListLayers(mxd)[0]
    arcpy.AddMessage(county_layer)
    arcpy.SelectLayerByAttribute_management(county_layer, "NEW_SELECTION", expression)
    df = arcpy.mapping.ListDataFrames(mxd)[0]
    df.zoomToSelectedFeatures()
    arcpy.RefreshActiveView()
outputPath = outfolder + os.sep + "Map.png"
arcpy.mapping.ExportToPNG(mxd, outputPath)
arcpy.SetParameterAsText(2, outputPath)
Thank you,
Aaron
JonathanQuinn
Esri Notable Contributor
You can probably use a combination of a Search Cursor and an extent object to set the data frame extent:
import arcpy
inGeom = arcpy.GetParameter(0)
mxd = arcpy.mapping.MapDocument("CURRENT")
for row in arcpy.da.SearchCursor(inGeom, ["SHAPE@"]):
    extent = row[0].extent
df.extent = extent‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
SearchCursor—Help | ArcGIS for Desktop
Extent—ArcPy classes | ArcGIS Desktop
AaronPaul5
Hi Jonathan,
I would like the user to draw an extent. Not get extent from a records in a table or feature layer.
There is a built in functionality of Extract Data Tool that passes the extent in the way I'm thinking.
When using the tool in ArcCatalog, the user would have to select a data source to clip to.
In ArcMap the tool allows you to draw a rectangle to define extents.
It uses a shape called Area_of_Interest for the deault shape type.
My script will be published to ArcGIS Server, so it will be able to use a map to draw the extent.
I think if we get as far as using the draw Area_of_Extent, that would do it.
Please see screen shot of Extract Data
Thank you again,
Aaron
JeffBigos
Hi Aaron,
The parameter data type that the Area Of Interest is using above is a FeatureSet. It can be used to allow a user to either dynamically draw and input geometry (point, Line, Polygon) or browse for a Featureclass.
The important part of that parameter in the script tool is the schema property, The FeatureClass you use for the schema defines two things for the FeatureSet:
   1. Geometry type
   2. Field type and names
As Jonathan mentioned above you can then use a cursor to get the drawn geometry from that parameter.
I have used this technique before in both Desktop (Custom Toolbox Tools) and Javascript Applications (consuming GP Services)
Jeff
