Adding internal links to cascade story map
1437
07-24-2018 02:31 PM
YosefBodovski1
I am trying to add some internal links to the story map built with cascade template. I was able to find some custom code here: https://developerscorner.storymaps.arcgis.com/adding-links-to-sections-in-cascade-930a091365c0
I added this code to the custom-scripts.js file after I deployed my app to our server, but it doesn't really help. Any ideas?
Thanks!
AdamPfister
Hi. I'd be more than happy to help you out. Are you able to post a link to your app running on your server so I can take a look?
Adam
YosefBodovski1
Hi Adam, here is the link http://redlands.pop.psu.edu/storymap/index.html . I didn't build this app, just hosting it on our server. I can send you the original AGOL link if you like. Thanks!
AdamPfister
Sorry for the delay. I just pulled up the application and the links in the story appear to be functioning correctly. Are you still seeing an issue? Which browser are you using? I am using Google Chrome 68.0.3440.84 (Official Build) (64-bit).
