I have MS Office 2010 Professional on a laptop mostly just using Excel. For some reason, the program crashes frequently when I am opening xls document.
Any ideas on what is going on? I really need to fix this before next Sunday. Thanks.
Solved! Go to Solution.
To resolve this problem, try the following methods, as appropriate, in the given order:
1.
- On the Start screen, type Control Panel.
- Click or tap Control Panel.
- Under Programs, click or tap Uninstall a program.
- Click or tap Microsoft Office 365, and then click or tap Change.
- Click or tap Online Repair, and then click or tap Repair. You may have to restart your computer after the repair process is finished.
2.
Сheck whether the file associations in the system are performing correctly, reset the Excel file associations to their default settings.
If you still experience this problem after you try all the methods, click here for additional help: http://www.xls.repair/
MS Office? Does it have anything to do with ArcMap or ArcGIS Pro?
If not, could be a problem with that program
1.
2.
