Selection symbol for Graphics Overlay
1117
5
07-22-2018 06:16 AM
VishnuB
Currently there is only one option to change the selection property of selected graphics in a GraphicsOverlay, and that is by changing the selection color. Instead of changing selection color, Is it possible to set a selection symbol for selected graphics (for eg: a square box around the selected graphics)
LucasDanzinger
Esri Frequent Contributor
Hi Vishnu-
It is not possible at this time.
LucasDanzinger
Vishnu-
What is your use case for wanting a selection symbol instead of just modifying the color?
VishnuB
Hi Lucas,
Thank You for your response.
The MIL standard which i am following to develop the application strongly recommend to show a red rectangle (Military Symbology) around the selected point symbol. As a work around i had done this by creating a new graphicsLayer and display the rectangle symbol using picturemarkersymbol around the selected entity. If the selected entity is a moving object i need to update the geometry of the rectangle symbol along with the selected entity. It will be good if this feature gets implemented in the feature release.
Thank You.
LucasDanzinger
Thanks Vishnu. Which MIL standard are you using?
TroyFoster
You could just take the symbol geometry's envelope and draw that?
