How to animate wind direction using ArcGIS Pro
1408
07-19-2018 12:05 PM
JasminMoxham
I have data from a weather station.  It is a table with time, date and wind direction.  I have used different symbols for each wind direction used in the table.  I have tried animating it using range and either the arrows appear all at once or not at all.  I am not sure what I am missing.
XanderBakker
Esri Esteemed Contributor
If all the data appears all at once, it might be due to some configuration when you enable time: Set the time properties on data—ArcGIS Pro | ArcGIS Desktop , or maybe some records do not have time or values very far away (in time) from the bulk of the data. These outliers will cause the interval to be large and might cause large parts of the data to be shown at once (in a single interval).
