EXIF Function Error in Survey123 Web
2521
5
07-11-2018 08:20 PM
EmilynMabini
Why is it that the exif function to get the metadata of the photo is not functioning in the Survey123 Web Version but it works fine in the Desktop version. Is there an equivalent function of exif in the survey123 Web so I can still display the metadata of the geotagged photo?
Desktop Version
Web Version
Please help me. Thank you.
JohnathanHasthorpe
Hi Emilyn
There are a couple of differences in the way the web app handles EXIF compared to Connect:
  • Currently, the pulldata @EXIF function does not work if there are any other strings/chars in the same cell of the the function -  e.g. you can't put a string() function around the pulldata function.
  • Currently, the pulldata @EXIF function does not work if there are additional questions as inputs ${ }, other than the image question. See the following examples:
    • pulldata("@exif", ${image}, "gpslatitude") - will work
    • string(pulldata("@exif", ${image}, "gpslatitude")) - will not work
If you stick to the above rules, your survey will work.
John
JohnathanHasthorpe
Hi Emilyn
John
EmilynMabini
Hi Johnathan,
Thanks for answering my question. Yes the 'pulldata("@exif", ${image}, "gpslatitude")' works fine. The image is in a repeat so once I click the "plus" icon to add an attachment the coordinates metadata are being pulled from the first attachment. However the 'pulldata("@exif",${image},"ImageDateTime")'   is not working. See screenshots below.
Picture 1: Before clicking the "Plus Icon"
Picture 2: After clicking the "Plus Icon"
Thank you,
Emilyn
JohnathanHasthorpe
Hi Emilyn - I have replicated the issue and have raised it with our development team.
I'll update this post when I know more.
John
JodyZhengLiu
Hi Emilyn,
This has been fixed in the web app and will be available for our next release (version 3.4) late May. Would you please have a try then?
Thanks and best regards,
Jody Zheng Liu
EmilynMabini
Thanks a lot!
