Take Minimum value of multiple raster using ArcPy
4138
7
07-12-2018 02:29 AM
ShouvikJha
Hi all,
I have monthly raster for different parameters in three different folders. I am trying to take the minimum value of raster from each raster in two different parameters and solve the below equation. For that, I have written a code, but the code is producing an error.
It is giving an error in line no 35.
Sample data attached below
Code:
def main():
    import arcpy
    import os
    # Checkout extension
    ws_in_APAR = r'E:\APAR'
    ws_in_TSCALAR = r'E:\T_SCALAR'
    ws_in_WSCALAR = r'E:\W_SCALAR'
    ws_out_GPP = r'E:\GPP_1982'
    # list "mean" rasters (r001_APAR so on)
    arcpy.env.workspace = ws_in_APAR
    lst_ras_APAR = arcpy.ListRasters()
    print "lst_ras_APAR", lst_ras_APAR
    # list "mean" rasters (r001_TSCALAR so on)
    arcpy.env.workspace = ws_in_TSCALAR
    lst_ras_TSCALAR = arcpy.ListRasters()
    print "lst_ras_TSCALAR", lst_ras_TSCALAR
    # list "mean" rasters (r001_WSCALAR so on)
    arcpy.env.workspace = ws_in_WSCALAR
    lst_ras_WSCALAR = arcpy.ListRasters()
    print "lst_ras_WSCALAR", lst_ras_WSCALAR
    for ras_name in lst_ras_APAR, lst_ras_TSCALAR, lst_ras_WSCALAR   :
        ras_APAR = arcpy.Raster(os.path.join(ws_in_APAR, ras_APAR))
        ras_TSCALAR = arcpy.Raster(os.path.join(ws_in_TSCALAR, ras_TSCALAR))
        ras_WSCALAR = arcpy.Raster(os.path.join(ws_in_WSCALAR, ras_WSCALAR))
        # calculate (ras_TSCALAR.minimum wil take the minimum value of perticular raster)
        ras_GPP = (ras_APAR * 1.48) * (ras_TSCALAR.minimum * ras_WSCALAR.minimum)
        # save raster
        ras_num = ras_name[:3]
        out_name_GPP = os.path.join(ws_out_GPP, 'r{0}_GPP'.format(ras_num))
        ras_GPP.save(out_name_GPP)
if __name__ == '__main__':
    main()‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Error message:
  File "E:\GPP.py", line 64, in <module>
    main()
  File "E:\GPP.py", line 47, in main
UnboundLocalError: local variable 'ras_APAR' referenced before assignment‍‍‍‍‍‍‍‍‍‍‍‍
XanderBakker
Esri Esteemed Contributor
Have a try with this code (change the paths on lines 8 to 11):
def main():
    import arcpy
    import os
    ws_in_APAR = r'C:\GeoNet\MinMultiRas\APAR'
    ws_in_TSCALAR = r'C:\GeoNet\MinMultiRas\T_SCALAR'
    ws_in_WSCALAR = r'C:\GeoNet\MinMultiRas\W_SCALAR'
    ws_out_GPP = r'C:\GeoNet\MinMultiRas\GPP_1982'
    if len(lst_ras_APAR) == len(lst_ras_TSCALAR) == len(lst_ras_WSCALAR):
        print("each list has equal amount of rasters, let's assume they match...")
        for i in range(len(lst_ras_APAR)):
            ras_APAR = arcpy.Raster(os.path.join(ws_in_APAR, lst_ras_APAR[i]))
            ras_TSCALAR = arcpy.Raster(os.path.join(ws_in_TSCALAR, lst_ras_TSCALAR[i]))
            ras_WSCALAR = arcpy.Raster(os.path.join(ws_in_WSCALAR, lst_ras_WSCALAR[i]))
            for ras_path in [os.path.join(ws_in_APAR, lst_ras_APAR[i]),
                             os.path.join(ws_in_TSCALAR, lst_ras_TSCALAR[i]),
                             os.path.join(ws_in_WSCALAR, lst_ras_WSCALAR[i])]:
                arcpy.CalculateStatistics_management(ras_path)
            print("ras_TSCALAR.minimum: {}".format(ras_TSCALAR.minimum))
            print("ras_WSCALAR.minimum: {}".format(ras_WSCALAR.minimum))
            # save raster
            ras_name = lst_ras_APAR[i]
            ras_num = ras_name[1:4]
            print out_name_GPP
    else:
        print("raster list have unequal number of items, aborting process...")
    arcpy.CheckInExtension("Spatial")
    main()
What I changed was the way the rasters are extracted from the lists and I included a calculate statistics since for some reason they are not present and that caused the minimum value to be None.
DanPatterson_Retired
to use …. for in …. syntax you need to provide an iterable like a list
for ras_name in [lst_ras_APAR, lst_ras_TSCALAR, lst_ras_WSCALAR]: # note the encompasing [ ]
ShouvikJha
Dan Patterson‌, please can I get an example, it will help me to understand further
It is safer to cast the iterable as a list
a_list = [1, 2, 4, 3, 7, 6, 5]
counter = 0
for a_value in a_list:
    print("number {} has a value of {}".format(counter, a_value))
    counter += 1
number 0 has a value of 1
number 1 has a value of 2
number 2 has a value of 4
number 3 has a value of 3
number 4 has a value of 7
number 5 has a value of 6
number 6 has a value of 5
the way you have it you are passing a list as an iterable, so the whole list is passed.
If you want individual values from those lists then you can enclose them then unpack
for a_value in [*a_list, *a_list]:
    print(a_value)
6
5
6
5
Or if you need to pair objects, then you can use zip (I think it works in python 2, but it certainly works in python 3.
for a_value in list(zip(a_list, a_list)):
    print(a_value)
(1, 1)
(2, 2)
(4, 4)
(3, 3)
(7, 7)
(6, 6)
(5, 5)
In short... make your iterable explicit and don't rely on providing the iterable as you have done
ShouvikJha
Hi Dan Patterson‌, Thanks, I am trying to follow your suggestion
ShouvikJha
Hi Xander Bakker‌, please can you look at the code. Thanks
XanderBakker
def main():
    import arcpy
    import os
            # save raster
            print out_name_GPP
    else:
    main()
ShouvikJha
Xander Bakker‌, Thanks. It's working fine
