Iterate an annotation feature class in arcpy
1642
07-11-2018 11:20 AM
BrianWilson
I finally figured out how to iterate an annotation feature class in arcpy to update its attributes.
You cannot use a cursor , it just generates errors. You cannot directly use SQL and bypass arcpy because the attribute columns are just for show, the real data is hidden in a binary column you can't see in ArcGIS.
But you can use CalculateField_management.
Roughly put,
codeblock = """def writekv(k, v)
  # do some calculation here, put it in "newvalue'
  return newvalue
expression = "writekv(!%s!, !%s!)" % (keyfield, valuefield)
arcpy.CalculateField_management(layer, fieldname, expression, "PYTHON_9.3", codeblock)
where keyfield and valuefield are the names of attribute fields you want to use
and fieldname is the name of the attribute being calculated.
All the normal python rules apply of course - indentation and you can use "import" and so on. I have been writing functions in the main body of my python script so that I can write unit tests, get the calculations correct, before getting into wrapping the code in a "codeblock" string. In this case the code looks something like this
#big long lookup table here
lut = { 1:"fine", 2:"dandy" }
def myfunc(x):
  # do some long python thing here
  y = lut # use a lookup table you've carefully tested in advance
  return y
codeblock="""from thisfile import myfunc
def f(x):
  return myfunc(x)"""
arcpy.CalculateField_management(layer, "SomeTextField", "f(!INTEGERFIELD!)", "PYTHON_9.3", codeblock)
This puts just the minimum needed inside "codeblock" (making it all much easier to debug) and in my example runs a function called myfunc that you can test separately.
This assumes all your code is in a file called "thisfile.py". In "codeblock" it does an import, that is so that the copy of python running in the field calculator can use a lookup table called lut that's declared outside the function "myfunc".
I have to adjust the font sizes in 300,000+ records and this is working for me.
MichaelVolz
Esteemed Contributor
How long does this take to run on 300,000+ records?
