Using select multiple as a type with follow-up questions
2816
07-10-2018 10:54 PM
GrietaMarivic
I have done survey with conditional questions and tried the select one as a type (yes or no) for "kind of rice". Whenever I choose the "Yes" answer for B1a in FIES_1 form, the follow-up questions in the red box appears, but it looks redundant when putting a yes or no for every question under B1. So, I tried again the select multiple as a type in FIES_2 form. However, when I checked the A and/or B under Kind of rice, I want to show the follow-up question in the red box. but it is under A or B. Hence, if I uncheck either A or B, it will hide the follow-up questions.
Thanks in advance!
IsmaelChivite
Esri Notable Contributor
I am not sure I completely understand the question, but it seems like you may want to use selected(${question},'value')
See more details here: https://community.esri.com/groups/survey123/blog/2017/08/30/understanding-multiple-choice-questions-... , particularly the Common Errors and Tips section towards the end.
